5 speed manual transmission
Discussion in 'General Maverick/Comet' started by zorares, Mar 1, 2012.
  1. zorares
    zorares Member
    Midlothian, Texas
    1973 Ford Maverick
    Well, after much thought, I've decided to blow off my wife, replace the bench front seat with bucket seats and convert the 3 speed on the column to a floor shift 5 speed. Question is, what transmission should I get? I currently have the original 1973 302.
  2. Earl Branham
    Lugoff, SC
    Best and easiest to convert is a T5. Lots of info on here, just go to the search function, type in T5. Good luck.....not with the car, with the wife!!!:rofl2:
  3. CaptainComet
    Later T5s were called "World Class" and built a bit stronger ... I want to say 1990 and later, but not sure.
  4. zorares
    zorares Member
    Midlothian, Texas
    1973 Ford Maverick
    I'm getting a little confused on fitting a T5 to a 302. Would there be a problem hooking a 1990 T5 to a 1973 302?
  5. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    The bellhousing from a later model 5.0 as well as from a 3.8 V6 will both bolt directly to a 302. You may have to change your flywheel and starter setup, but other than that its pretty straight forward. Then you've got the clutch to figure out. You can buy an adaptor plate that allows the use of your existing mechanical linkage, adapt the pedal for a fox body clutch cable, or build a hydraulic setup. All depends on your money and fabrication limits, as well as what type of clutch feel you prefer. It's an amazing transmission, completely changes the car.
  6. bmcdaniel
    You can even buy an adaptor plate to bolt the T5 to your current bellhousing and use the existing clutch linkage. That's how I did mine. Just have to modify the trans crossmember.
  7. bmcdaniel
  8. Reeves1
    Reeves1 Member
    Alberta Canada
  9. CaptainComet
    Blown76Mav, thanks for the year clarification. I was researching this about 5 years ago, and couldn't find my notes.
    As far as bolting one to a 73 302, one thing to watch will be the balance weight on the flywheel. It changed on the later 302s, so you need one with the proper weight. You will not be able to use one that came with the trans.
  10. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    the tranny swap is the easy part good luck with the wife
  11. bmcdaniel
    The transmission doesn't care what flywheel you use, just the engine cares.
  12. zorares
    zorares Member
    Midlothian, Texas
    1973 Ford Maverick
    So would I go with the flywheel from the engine or get a new one for the transmission?
  13. CaptainComet
    The flywheel that is with your engine would be a good choice if it is still serviceable (perhaps it needs a clean-up at the machine shop).
    This is provided that it will work with the combo of other parts you put together (clutch, bellhousing, starter, etc.).
    The clutch in my first Comet was pretty small, and I replaced it with a bigger Hayes street/strip clutch. Pretty sure we kept the stock flywheel.
    The really important thing is the balance weight on it has be the early spec.
  14. bmcdaniel
    You have to use a 28 oz imbalance flywheel on your old 302, which is what your current flywheel is obviously. Unless you have some reason for wanting to change the bellhousing, clutch, clutch linkage, starter, etc, just get the adaptor listed previously and bolt up the T5 using all of your existing parts. The T5 crossmember mounting pad is about 1 1/2" farther rearward than your 3-speed's pad so you have to modify the crossmember or fab a new one.
  15. beng19999
    beng19999 Member
    longueuil
    comet 1976
    i had that balance problem ,when you have a 302 before 1980 you need a 28 onces flywheel and after 1980 you need a 50 onces flywheel
