5-speed pedals question
Discussion in 'Transmissions' started by dlevi2121, Feb 10, 2009.
  1. dlevi2121
    dlevi2121 New Member
    Brownsville,Ohio
    :bananamanHello all I have looked around at some diffrent post and I have found out alot about putting a 5-speed in my 70 Maverick but I have not seen anything about what everyone is using for the pedals should I use the ones from another Maverick or the Mustang I am robbing the trans from? I have a set of pedals from a 66 Mustang with the Z bar and everything just want to clear this up before I start on my 70 project I would like to have all the stuff I need before hand thanks all any info is great.:tiphat:
  2. mean_maverick
    i used my factory Maverick pedals in mine with a small amount of mod's. most do the same as maverick/comet pedals are the only ones u can use in our cars to my knowledge
  3. dlevi2121
    Brownsville,Ohio
    Well I guess I will have ti try and find a set of those all I got is the 86 stang and 66 pedals then thanks for the info though.
  4. bmcdaniel
    I used the original Mav pedals with 66 Mustang linkage. The Mustang linkage is cheap and can be bought at any Mustang supply house.
  5. dlevi2121
    Brownsville,Ohio
    What do you mean using the stang linkage not the cable setup do you have any pics of this?
  6. bmcdaniel
    66 Mustang z-bar, pivots, lower rod, fork, fulcrum (pivot).
  7. dlevi2121
    Brownsville,Ohio
    All of the 66 parts I have are the 200 I 6 with the three speed on the floor are they the same as what I would need for the T-5 or do they hae to be for a V8 car?
  8. bmcdaniel
    If you're using the original bellhousing with a T5 adaptor plate and staying with the 6-cylinder you use the 6-cylinder linkage parts.
  9. dlevi2121
    Brownsville,Ohio
    I am using the v-8 t-5 trans on a 289 but the linkage parts I have are from a 66 stang
