5 speed transmission
Discussion in 'Transmissions' started by 1970mavinator, Jun 26, 2006.
  1. 1970mavinator
    1970mavinator Member
    Ruskin, FL
    1970 2dr I6 maverick
    I have a 70 maverick with a 200 inline 6. I was wanting to know what 5 speed transmission would bolt up to the 200. If anybody has done this or knows anything about it please help me out! I know the 200 already gets great gas mileage, but I have heard that a 5 speed with the 200 gets up to 38 per gallon.
  2. Mavaholic
    You can get an adapter plate from any mustang supply house to bolt a T5 to your set up. You will have to fabricate a rear mount and have your drive shaft shortened but thats pretty easy stuff.
  3. 1970mavinator
    Ruskin, FL
    Thanx for the help. Are you referring to the adapter between transmission and bell housing or bell to motor
  4. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    I thought the T5 and the 170/200/289/302 etc all shared the same bolt pattern. Is this not the case?
  5. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    170/200 bellhousings are different than 250/302 bellhousings. The Spacer plate is to compensate for the longer input shaft ... not bellhousing mountings.
  6. ModMav71
    ModMav71 Member
    Sebring, FL
    We That link should take you to Ford Six Tech page but I think they are having some tech problems. They have all the info you need to swap a T-5 to a 200 six. There are 8 different bellhousings for the 144/170/200. And 2 or 3 bolt starters. So you have to figure out what you have using there page and get the right adapter. I have it all printed out but its WAY TOO much to type (9 pages). I think all require a zero imbalance flywheel. If you had a 250 you would be good to go. No adapters needed.
  7. Jamie Miles
    Alto, GA
    I've had a few
    Just wondering what kind of mileage you're getting out of your 200?
  8. Mavaholic
    The bell housing may be different between the different motors, but all Mavericks and Comets used the same transmission. THe pattern of the transmission is different between the 3 speed and the T5. Also the T5's input shaft is about 9/16" longer. THe adapter plate is that thickness to space the transmission out, plus adapts the T5 pattern to the bell housing transmission pattern. Makes it a bolt in deal. Then you just have to deal with the mount and drive shaft length.
  9. maverick5.0
    maverick5.0 Member
    Caribbean/Puerto rico
    1976 maverick,347 stroker,c-4,sm bumpers,frt air dam/73 maverick,5.0 grabbber hood,four on the floor,v8,rear spoiler,...
    I agree too !! a 250 cid would be a better power plant and to some point more
    economical at the long run, as in parts adaptation and smother responce. with
    that 5 speed. good top end to boot !!
  10. 1970mavinator
    Ruskin, FL
    I get mid 20's
  11. 1972Grabber
    1972Grabber Always Broke
    SAN ANTONIO, TEXAS
    1972 Maverick Grabber
    Aren't quarter mile times supposed to be in the Drag Racing part of the forum? :biglaugh: :rofl2: J/K
    20 MPG - Thats pretty decent!
  12. Jamie Miles
    Alto, GA
    I've had a few
    Hmm, and you still have the stock ignition? I should be able to get my 200 up to high 20's then by upgradeing the ignition and a few other things.
    I'm getting mid 20's out of my 250, seems to be about the most I can squeeze out of it.
  13. 1970mavinator
    Ruskin, FL
    would a 5 speed from a 300 cid engine work without adapters?
  14. Mavaholic
  15. 1970mavinator
    Ruskin, FL
    what transmission would be my best bet to just bolt on that is not a 3 speed?
