6 speed transmission
Discussion in 'Transmissions' started by brainsboy, May 11, 2010.
  1. brainsboy
    brainsboy Member
    Tampa
    My C-4 is not really cutting it for highway use. I have been looking into going with a T56- 6 speed transmission and curious if anyone has done that conversion?
  2. justin has a 74
    kentucky
    That should be fun lol. I hope someone does it.
  3. PaulS
    What is wrong with your C4? What rear gears do you have?
  4. brainsboy
    brainsboy Member
    Tampa
    2.79 gears but Im still pushing 3100rpm at 75mph on the highway. The 6 speed transmission has a .80 5th gear and a .50 sixth gear which would be pretty nice for crusing the highway.
  5. justin has a 74
    kentucky
    Thats a little high for 2.79 gears:16suspect
    Im running 2700.
  6. bmcdaniel
    A T56 is huge x large with a built on bellhousing. Even a T5 will get your highway rpms down to 2000.
  7. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    you should look into the T5 as mentioned above, cheaper to come by, way easier to install, and I have 3.25 gears, 27" tires and with my T5 I'm at 2200 at 75 . . . works great for me
