6 to 8 distributor question
Discussion in 'Technical' started by ncmaverick1977, Jun 29, 2011.
  1. ncmaverick1977
    ncmaverick1977 Member
    Burlington, Ia
    1977 Maverick
    Before I go buy a '77 v8 distributor, will it work with the I6 ignition of the same year? I checked the parts supply websites and the ignition modules have the same part numbers. Background: I have a 77 Mav. with the 200 and 3 speed. I've already put in a 68 302 and a 5 speed with a hydraulic clutch. Now I'm working through the details. The 302 has the Pertronix conversion but I understand the pertronix doesn't work with the duraspark ii. I'm not ready to do a hi-perf. MSD since it sounds like the DS is more than adequate for my needs. Thanks for your thoughts.
  2. rthomas771
    You can not use a 6 cyl distributor in a V8. The Duraspark II ignition module will swap out between a 6 and V8 as long as the wiring harness has the same number of wires. My opinion is the DS II is better than Pertronix.
  3. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    There is a difference on some 6 and 8 cylinder modules. As long as the tab where the wires go into the module is BLUE then you will be OK.
