65 Styled Steel Wheels 15 " X 7 or 8 ?
Discussion in 'Wheels and Tires' started by DougsSpeedShop, Feb 16, 2013.
  1. DougsSpeedShop
    DougsSpeedShop Member
    Ontario
    1973 Comet
    Hi:
    Still toying with different styles/types of wheels for the Comet...its a big decision so taking my time..what with clearance/fit etc...
    Was wondering if anyone is running the 15 inch styles steel wheel 7 or 8" now available? I thought they woud look good but concerned about clearance's.
    I have a modified ride height and running a 9 inch Ford (slightly wider than stock) and Cragar Quick tricks. 15 X 8 with what appears to be a 3 to 3.5 back space. 255/60/15 TA's . No clearance issues.
    The styled steels 7 inch provide a 4.25 BS and the 8's have a 4.5" BS.
    If anyone runs these on their ride or know of some who does/has, let me know please.
    As the saying goes, once you buy em they're yours" and I want to make the right choice. See attached. The shot of my car with the wheels on it is a cut and paste to give an idea of what the wheels would look like.
    Thanks,
    Doug
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    A 255/60-15 will hit the leaf-springs and inner fender wells with a 4.5" backspace unless you run a wider rear-end.
  3. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    wheels
    Rear 15X8 With a 4 1/2 in Backspace and 255/6015 there is clearance of about 5/16 in to spring and suspension bumper brkt there is aprox. 1/4 between sidewall and fender lip, I am going to space these out with a 1/4 spacer.
    Front 15X7 With a 4 1/4 in Backspace and 215/6515 there is tire rubbing the the frame rail behind the wheel on full turn. I am going to space this one between 1/4 and 1/2 in. 3 3/4 backspace on the front is about maximum unless you dont mind spacers.
  4. scooper77515
    On mine, 255/60-15 clear the springs, but hit the inner fender on hard launches. But work fine after I rolled the inner fender lip.
    You shouldn't have a problem, since your car sits so high above the tire.
    Looks nice, by the way! :thumbs2:
  5. Dave B
    I don't think I've ever seen those wheels on a Maverick, I wonder if they fit over the stock Maverick from disc brake rotor?
  6. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    the original 14 in probably wont but hes bying 15 inch Reissues
  7. DougsSpeedShop
    Ontario
    1973 Comet
    Hey Scooper- Thanks for the reply - What wheels and specs are you using...also what rear end set up do you have?
    Cheers...Doug.
  8. DougsSpeedShop
    Ontario
    1973 Comet
    Hey Dave - I have a Granada disc brake set up on the front. Currently running old Cragar Super tricks - 14 X 6. maybe 7's.
    Doug
