69.5 Dash Ignition
Discussion in 'Technical' started by joshua_mcgehee, Jun 5, 2008.
  1. joshua_mcgehee
    joshua_mcgehee Member
    Montana
    1971 Comet
    Has anybody ever installed on a 71 on up Comet. I got the wires going to the ignition switch up to the dash. If anybody has done this before what wires go to what. Some of the wires are the same, but other are not.
  2. joshua_mcgehee
    Montana
    1971 Comet
    Nobody has done this?
  3. 71gold
    do you have the '69.5 steering column?
    ...Frank...:drive:
  4. joshua_mcgehee
    Montana
    1971 Comet
    Yes, I have the complete column from the 69.5 Mav. Not to mention alot of every other thing that I can get my dirty big hands on.
  5. myselfandiamho
    myselfandiamho Member
    hayden al
    1969.5 2dr 6cyl auto
    joshua the turn signal coupler on the 69.5 will plug up on your conector but nothing works. the69.5 has a completely different wireing diaghram than the 70 and up maves. i searched for a 69.5 wireing diaghram but never found one. i had to run jumper wires across the two connectors to wire mine to make it work properly. maybe someone can help us both by telling us where to go to get wireing diaghram for the 69.5 as this would simplify knowing what colors go where. good luck!!!
  6. joshua_mcgehee
    Montana
    1971 Comet
    As a matter of fact, my column that I got from a 69.5 Mav, the turn signals do work. I just want to go ahead with the complete transfer. Later, I'm heading to the Junkyard.
