69.5 gas tank
Discussion in 'General Maverick/Comet' started by grabberguy16, Sep 28, 2010.
  1. grabberguy16
    grabberguy16 Member
    Courtenay, BC, Canada
    72' 2dr Maverick,70' 2dr Maverick
    I have a question do the risen parts of the outside of the gas tank mean anything?
  2. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    What parts are you talking about? There are 2 different tanks that go in a 69.5/70. One tank without a fancy evap vent on the top (California emissions) and one with.
  3. rthomas771
    The 1970 system consists of a sealed fuel tank filler cap, an expansion area at the top of the gas tank, a combination vapor separator and expansion tank assembly, a 3-way vapor control valve, a carbon canister located in the engine compartment which stores these vapors, and the hoses which connect this equipment. The 1971-77 system consists of a special vacuum/pressure relief filler cap, an expansion area at the top of the fuel tank, a foam-filled vapor separator mounted on top of the fuel tank, a carbon canister which stores fuel vapors and hoses which connect this equipment. On both systems, the carburetor fuel bowl vapors are retained within the fuel bowl until the engine is started, at which point they are internally vented into the engine for burning. As the gasoline in the fuel tank of a parked car begins to expand due to heat, the vapor that forms moves to the top of the fuel tank. The fuel tanks on all 1970 and later cars are enlarged so that there exists an area representing 10-20% of the total fuel tank volume above the level of the fuel tank filler tube where these gasses may collect. The vapors then travel upward into the vapor separator which prevents liquid gasoline from escaping from the fuel tank. The fuel vapor is then drawn through the vapor separator outlet hose, through the 3-way vapor control valve (1970 only), then to the charcoal canister in the engine compartment.
  4. grabberguy16
    grabberguy16 Member
    The drop in tank
  5. mav1970
    Are you talking about any raised areas built into the sheet metal of the tank? If so, I would say that they are there to provide strength to the overall shape of the tank.
  6. grabberguy16
    grabberguy16 Member
    Yes that is what I ment so its only for strength IS there anything inside the tank? what holds in the fuel sender unit it thingy
  7. Fordmaster169
    Coos Bay, Oregon
    The fuel sending unit is held in with the bezel on the outside of the tank, nothing is connected to the inside.
  8. grabberguy16
    grabberguy16 Member
    Okay thanks for the help
  9. bmcdaniel
    My 70 never had any of that. And it's a late 70 model.
  10. mav1970
    Mine either :huh:
  11. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    Mine either. The only thing between the fuel line and the pump, is the filter I put in.
  12. Craig Selvey
    It was a California Emmissions thing. I had a 1970 Maverick with it. What a set-up!!
