7.5in rearend to an 8in swap
Discussion in 'Technical' started by 75Mav91Stang, Mar 19, 2008.
  1. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    1970 and 1975 Ford Maverick
    I want to swap the 8in from my '75 into my '70 which is a 7.5in. Is it just a direct swap? Any tips would be great because I've never swapped rears before
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    shouldnt be any problems, im not sure on shock locations...im not sure if the 70 has stagerd shocks or not
    i did my rear by myself, and its not even from a maverick:D
  3. Jamie Miles
    Alto, GA
    I've had a few
    It should be a straight forward swap.
  4. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    shock mounts are on the spring plates. If you use the plates from the 70, you should be a o k. (I think)
  5. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    Thanks Shaun (and everyone else too :oops: ). I'll take a look when its not raining out. Anymore info?
  6. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    get them brakes freed up!
