7 inch brake booster
Discussion in 'General Maverick/Comet' started by Spillman, Sep 28, 2008.
  1. Spillman
    Spillman Scott
    New Port Richey, Florida
    1971 Comet 306
  2. Dave B
    Someone on here has one similar, maybe they'll pop in and let you know where they got it. A few years ago, there was a post somewhere on the net about using a Geo Metro booster, and they did the conversion on a Falcon, I'll see if I can find the link.
    I used a 1" bore Willwood master cylinder on my car, so far it seems better tahn the stock mc did with the front brakes, but I plan on doing the Cobra conversion, so we'll see. (I was ebay shopping for the stuff yesterday) :)
    Here's one link: http://www.joesfalcon.com/page33.html
  3. Mavaholic
    If it is 11" or shorter from mounting surface to end of master cylinder, it would at least fit behind the shock tower. Don't know what all mods would have to be done to make it fit. I bought a booster/mc set up from ABS Power Brake Inc. Only mod that has to be done to your car is the large hole in the firewall needs to be opened up another 1/8". Also if you order from them, you have to specify you need the mounting studs to be 1 1/2" longer (in addition to what comes on it). I got part #9786 which is for 4 wheel disc. I think the part number for disc/drum is 9784 but call them and verify.
    http://www.abspowerbrake.com/index.html
  4. Spillman
    Spillman Scott
    1971 Comet 306
    Thanks Guys!
