70 3 speed manual column
Discussion in 'Technical' started by redfivexw, Jul 10, 2014.
  1. redfivexw
    redfivexw Member
    My 70 maverick was running and driving great, no problems with shifting, etc. Suddenly during a shift the car lost the ability to shift. My mechanic says the column is bad, says it is common with these cars. Should i just look for a used column, does anyone on the board have one? I have seen some talk of converting to floor shift, not sure what the best option is. any advice appreciated. I want the car reliable, we were supposed to take it to the Syracuse Nationals next weekend, doubt that will happen now.
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Years ago, I remember my friends column shift in his truck would get stuck occasionally. We would pop the hood and yank on the linkage to free it up and it would work fine for a while. The joy of old cars and worn parts.
  3. redfivexw
    redfivexw Member
    my mechanic already removed the column and said it is no good, something inside came apart and he says it is unlikely to find the parts to fix, recommeded finding a used one.
  4. Craig Selvey
    More than likely it is the shift collar on the column that is broke. Very common problem.
  5. redfivexw
    redfivexw Member
    is there a fix, or should i abandon the column? Craig, do you have one? Has anyone tried the conversion kit for floor i see in the autokrafter catalog?
  6. FomocoBoy
    FomocoBoy Member
    Western Canada
    1969.5 Maverick
    The first Maverick I got 35 years ago had what may be the same problem. The shifter moved but didn't move the arms at the bottom where the linkage to the trans hooked up. I took the column apart and found the shift tube(?) in the column was a 2 piece tube. One fitting inside the other and running down the column and out the bottom to the shift arms. There was a nylon type plug through the two tubes where they overlapped. I assumed this was a crush feature so the column would snap the nylon plug and collapse in a collision. I just tack welded the tubes back together. No more nylon plug, no more collapse if in a collision. Hope I'm remembering this correctly. 35 years ago is a long time ago....
  7. Jneto7
    Jneto7 New Member
    São Paulo
    Maverick
    Looking for Set of clear front parking/turn signal lamps with brackets
  8. redfivexw
    redfivexw Member
    My problem is like fomocoboy suggests
  9. Craig Selvey
    I have some columns and/or parts....but they will not be cheap. Email me DIRECTLY (see below) if I can help.
  10. redfivexw
    redfivexw Member
    The repair was exactly as fomocoboy
    said, weld the two tubes together and it works fine. Not quite a smooth as original, but useable.
  11. FomocoBoy
    FomocoBoy Member
    Western Canada
    1969.5 Maverick
    Glad it worked out for you.
