70 Maverick problems
Discussion in 'Technical' started by GreenMachine70, Aug 24, 2008.
  1. GreenMachine70
    GreenMachine70 Member
    Dayton, Ohio
    1970 Green Maverick 170 6 Cylinder
    So me and my dad are fixing up my 1970 Maverick. i got a few questions. 1st off the body is rusted in the normal spots such as the quarters, front bottom fenders, the trunk is a bit rusted and could use some maintance but for the most part that stuff is done. questions i have is. we pulled off the rear valence and the underneath of the car was a rust heaven. now i know you cant see it when i drive by and stuff but is their any easy way to make it look better and stop the rust other than welding in new plates and whatnot. another question is my break lights dont work. we have put new bulbs in and they still are out. we looked for the switch on the car but we couldnt find it. anyone know where its located at? Then we went to the door for the paint code so when we buy the paint we can get the original color. but the ass holes who owned it before us for some ODD reason scraped off all that great information off the door and now we cant tell what the letters are. i seen under the body that the 1st digit was a 6, then after that there isnt anything left. anyone know what the code could be, the origianl color is a dark green metallic color. Other than that i need to do a few minor tune ups on the engine such as new plugs and air filter and clean it up a bit. il try and get some pics of it up here in a few days.
  2. don graham
  3. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I went through Dayton yesterday!
    Welcome to the board!
  4. 72MAVGRABHER
    Roanoke, Va.
    if it's just "surface rust" and not cancer all the way through, you could use a rust inhibitor found at a local paint shop. you just slather it on, wait for it to turn to a gray color and dry then you can prime and paint cheaply.
    also, split up your paragraph, i read it probably 5 times before they stopped running together. but, thats probably the lack of sleep.(y)
  5. GreenMachine70
    Dayton, Ohio
    ok, thanks alot for the help i believe my paint is the ivy green, cause it seems
    like thatd be the only one that is close. As for the rust, its pretty much like
    Colon Cancer lol. Its not pretty under there. If i was making this into a show
    car id probably weld in new panels and get rid of it. but who knows thanks for
    the help fellas. :D
  6. igoback70
    igoback70 Member
    IN
    70 Maverick
    Hi green i know exactlly what you are refering to behind the rear valance (been there done that) if you go to my 1st post you can see what mine looked like and what i did to repair it if u think you do want to go through the trouble of replacing the rear subframe plate i can have 1 made for you but it is an extreme amount of work to replace. If you look closely at the plate thats on yours you will see indentions on each side where the plate meets the quarter panel drops. The one i can have made will not have the indentions on each side and it will be longer than that width wise (cut to fit) other than that it is exact. Lemme know if i can help in anyway if you decide to take it on.
  7. Bob Wiken
    Fayetteville, Arkansas
    Take out your seats. On mine there was a tag on the bottom of one that had that info.
  8. CaptainComet
    The brake light switch is attached to the brake pedal. It is attached with a C-clip. Easy to get to if the car is an automatic, miserable if it is a stick. It is probably easier if you remove the clutch pedal.
    I would test to see if you have power going to the switch first. When mine have failed, the brakes lights stayed on all the time.
    When Grabher said to break up your original message, he meant one topic/paragraph. Makes it much easier to try to figure out what you are asking if you are putting more that one topic in a post. Makes it easier for those of us with ADD ... oooo, did you see that? ... gotta go ... :rofl:
  9. 72MAVGRABHER
    Roanoke, Va.
    :yup:
  10. GreenMachine70
    Dayton, Ohio
    haha thanks guys yeah i just tried to read it and had some trouble too, i guess passing english with a D shows huh lol.. il check under the seat for the stuff and check on the brake light switch too. im also going to get some pics of it and put on here sometime in the near future :)
  11. GreenMachine70
    Dayton, Ohio
    k i found the switch for the brake lights, and the wires are cut, they are hanging there and i rubbed them to the + part on the switch and i had lights, so how do i go about fixing this? unscrew the little screw or what?
  12. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    Welcome aboard. What part of Dayton. I'm from West Carrollton. If I can help let me know.
  13. Dean Deeter
    Dean Deeter Member
    First check to see if the switch is good. If not replace it. Attach the wires to the switch to see if it is good or not.
  14. GreenMachine70
    Dayton, Ohio
    I live in Carlisle so not far from you at all =D. Ok i took the switch out and rewired it. my lights in the back work, but only 1 brake light works and we just put new bulbs in... so now what? lol
  15. Dean Deeter
    Dean Deeter Member
    Make sure you have a good ground. I would switch lights and see which bulb lights.
