70 maverick steering column problem
Discussion in 'Technical' started by jb70grabber, Sep 7, 2012.
  1. jb70grabber
    jb70grabber Member
    East windsor ct
    1970 maverick grabber 306 gt40 x heads and cam t-5 5 speed 8.8 rear 17 bullitt wheels also 76 low 22k 2dr undergoing restoration
    I'm currently at a locall show and on the way here I went through the gears and the steering wheel and steering shaft came out about a half inch and the can be slid back and forth does any one know what broke on me this is a early 70 with the key in the dash is it safe to drive home
  2. simple man
    simple man Member
    Bunnell,Florida
    Sounds like the upper bearing may have went bad or a snap ring popped off. I would check the flex coupling ( rag joint ) at the steering box and if it is in good condition I can't see where you would have an issue with safety. Make sure your turn signals and brake lights still work as the switch could have been damaged by the play. :)
  3. jb70grabber
    jb70grabber Member
    East windsor ct
    Thanks yes the turn signal switch is damaged and won't self cancel but as long as it won't pull out more than it is I'll drive it home
  4. 71gold
    have you had the steering wheel off lately?
  5. jb70grabber
    jb70grabber Member
    East windsor ct
    Not in years the wheel is definetly tight on the shaft it seems to be pulling the whole shaft with it I can see the wiring harness move with it
  6. simple man
    simple man Member
    Bunnell,Florida
  7. jb70grabber
    jb70grabber Member
    East windsor ct
    Thanks that will be very helpfull, I'm thinking I may have lost the snap ring or the bearing retainer broke
  8. Craig Selvey
    Sounds like a snap ring to me.
  9. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    X2, This happened to me about a year ago on my 69.5.
  10. junrai
    junrai Member
    rancho cordova ca
    the rag joint didnt break? sounds like the rag joint broke
  11. raydenaomi
    raydenaomi Member
    Louisiana
    1976 Ford Maverick
    hi guys just reading all the posts. Does this happen often. I have a 76.. HOpe you got the problem solved.
  12. rthomas771
    This is the 1st time I ever heard of this problem.
  13. Earl Branham
    Lugoff, SC
    My column was loose at one time, and the guy that fixed it said the bolts behind the turn signal switch worked loose. He tightened them up, and it has been perfect ever since. The symptoms were about the same, but it moved in/out and up/down. Check these, see if it helps. Good luck!
  14. jb70grabber
    jb70grabber Member
    East windsor ct
    I have owned this car for 9 years and it was the only time it has done that to me
  15. Earl Branham
    Lugoff, SC
    Did you check the bolts?
