71-74 Comet engine swap
Discussion in 'Maverick/Comet Projects' started by Eldrick, Jan 6, 2021.
  1. Eldrick
    Eldrick New Member
    Naples, TX
    71 Mercury Comet
    Hi, I'm new here.
    I'm about to buy a 71-74 Comet, that supposedly "runs" and has the I6 in it. So at this point, i can get a pontiac "Ford model" 400 4-barrell big block with the carb that needs a rebuild. For the people who don't know, the pontiac 400BB is ford design. Pontiac was close with ford back in 68-78
    So what would it take for me to transfer this 69 400BB over to a 71-74 comet?
    I really want to let my neighbors to have nightmares about the demonic sound theyll hear hehehe.
  2. Eldrick
    Eldrick New Member
    Naples, TX
    71 Mercury Comet
    Update it is a 1972 Comet
  3. 71gold
  4. Mavaholic
    My guess its never been done so your pretty much on your own. Best way to swap any big engine into one of these cars is to get one of the front end suspension kits that eliminate the shock towers. Plenty of room for just about anything at that point.
    rickyracer and Krazy Comet like this.
  5. Krazy Comet
    Pontiac 400 a Ford engine? First time in 50+ years I've heard that. In the '60s, Pontiac did use Ford's three speed transmissions.
    Anyway there is NO such thing as a Pontiac Big Block. All Poncho blocks are same size, whether it a early '60s 326 or a 455. Bell housing bolt pattern is shared with Olds & Buick.
    gator25, rickyracer, Shorty and 2 others like this.
  6. TeeEl
    TeeEl Senior Member
    Colorado
    Would make more sense to put a 400 SBC in there, since it would fit better and make the same power.
    Pretty sure Pontiac engines have ZERO association with Ford...
  7. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    Russell and Krazy Comet like this.
  8. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    That's an interesting swap. Not sure it'll be too easy. It's 5" wider than a sbf, has a rear sump rather than a front sump, and weighs 200 lbs more than a 302. If you go ahead it'll be fun and interesting to watch.
    gator25 and BBMS18 like this.
  9. Krazy Comet
    I suspect John DeLorean has rolled over in his grave.
    For those not knowing, in late '60s/early '70s, he was president of Pontiac Division. Yes same DeLorean that built namesake. Ford didn't introduce it's 400 till mid '71, makes no sense they'd build one for Pontiac three years earlier. No doubt someone fed the OP a line of BS.
    Other than F-Series fanciers, Ford's 400 doesn't have much of a following. Basically a "tall block" Cleveland design, without major surgery would never fit into a Maverick. The 351M is the tall block 400 stuffed with shorter stroke 351 crank. Big, heavy & bulky, not even the F-Series crowd cares much for those.
    gator25, TeeEl, mojo and 1 other person like this.
  10. BBMS18
    BBMS18 Member
    75 Comet
    There’s only 1 good thing about Ford’s 351/400 engine..... it’s easily replaced by a 429/460.:thumbs2:
  11. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    My parents had an LTD with a 400. That thing would do all kinds of peg leg burnout until the one spinning tire hooked. Then you realized you weren't going anywhere with any degree of speed. It did burn plenty of gas, though... :huh:
    BBMS18 likes this.
  12. Meangreen71
    Meangreen71 Member
    AL
    '71 Mustang/ '72 Mach / '74 Maverick/ '77Comet
    I have a Ford 400 engine in my Mach 1....with a few tweaks (750 carb, aluminum intake, roller rockers, performance cam, headers, under-drive pulleys, Accel ignition, flat tops, etc). -It's no slouch
    It's almost as wide as a 429/460
    Krazy Comet likes this.
  13. Krazy Comet
    Built with good heads, intake, cam etc it's no doubt a formattable opponent. A friend had a mildly built 400 in a '79 F-150, ran decent.
    Problem, I don't think Ford ever built one that didn't have a 2bbl carb or asthmatic, small port heads. To really run need borrow a few parts from the 351 Cleveland.
    The OP bailed after two posts, suspect he was just a drive by poster screwin' with the Ford boys.
    Sometime in late '80s I had a LTD with 400, coughed the timing chain, wasn't running. Called scrap guy to to drag it and couple other derelicts to their grave. A few years earlier I'd bought a Country Squire wagon to flip with 400, general POS. To its credit, when temps dropped to -3*F, was only vehicle I had that would start. No I'm not counting Cobra, was tucked away in garage.
  14. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    Also father of the GTO, Garbage Truck with Overdrive. Or Gas Tires and Oil as we called them.
  15. rickyracer
    rickyracer Member
    Central Nevada
    First you'd really have to be into some serious S&M. Otherwise go with a 460 and C-4, 9" 3.25 gears. You piss them off. As stated, just change some front end stuff. Remember, Dyno Don, Fast Eddie and others did a Boss 429 without Mustang II stuff.
