71 Grabber Susp/Trans question
Discussion in 'Transmissions' started by luisn, Aug 3, 2009.
  1. luisn
    luisn Member
    Riverside,CA
    Recently my uncle came across a grabber out in Sonoma,CA.He gave me the number for it and I called the guy up.We started talking about the Mav.
    Apparently the car has a 250 straight 6,but has v8 suspension and transmission straight from the factory.I found that to be interesting.The owner has documentation to prove it.I'm not to sure on it.I lack alot of knowledge but I'd like to know if this is could be true.
  2. Rando76
    Rando76 Member
    Claremore, OK
    V-8 suspension and transmission? You mean a C-4? The C-4 250 bellhousing will bolt onto a 302 and is the same transmission. If you're talking about the heavier suspension options (like a bigger anti-sway bar and 4-leaf springs), those were optional regardless of whether it was a V8 or not.
    Welcome to the boards. :Welcome:
  3. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Perhaps they are referring to 5 lug axles/hubs?
  4. Dave B
    I'd like to see it, next he'll say it had a Boss 302 in it at one time. :rolleyes:
  5. luisn
    luisn Member
    Riverside,CA
    I see.I was just a little confused.I'm seriously new to this.
    ^Thanks for the info everyone.Will most likely be buying the car so I will keep you posted.
    Just asked for the VIN.Is there any way I can go on decoding it?
  6. Matterick
    Matterick Matt Somerville
    Lake Stevens WA
    http://home.comcast.net/~petebre/maverick/decode/index.html
  7. Rando76
    Rando76 Member
    Claremore, OK
    You've come to the right place. (y) There's lots of great info here. If you buy it, post pics! We love pics. :clap:
  8. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    I am somewhat close to Sonoma, so if you need some one to check on the condition, etc, I may be able to get down there sometime. Also, if you pass I may be interested to check it out myself. Welcome to the board!
    -Corbin
