71 maverick dash lights out????
Discussion in 'New Members Forum' started by jtstein98, Nov 10, 2013.
  1. jtstein98
    jtstein98 Member
    near chicago IL
    1971 ford maverick
    just bought my first car and first maverick!! Sadly though the speedometer Light is out and it is impossible to drive it at night! If anyone could please tell me how to fix or check what the problem with it is that would be great!
    thanks, Jakob
  2. mav1970
    Some of your gauge lights might just be burned out - they are installed through the back of the gauge cluster through twist out black plastic holders :tiphat:
  3. jtstein98
    jtstein98 Member
    near chicago IL
    1971 ford maverick
    thanks!
    ok I removed the screws holding the gages and the glass and plastic in but it still wont pull out? Is there anything else I need to do to pull them out?
  4. Krazy Comet
    Did you check the fuse??? There is a very short 5A in the fuse block on the firewall(just above your left foot) that powers the dash lights... Also it's common for the resistor on the dimmer to be corroded, spinning it back and forth 8-10 times usually cleans them till they function again...
    If they are all out problem probably isn't bulbs,(there are three for general illumination, plus one in the transmission quadrant)...
  5. mav1970
    It's been a long time since I removed my gauge cluster but I believe the speedo cable might be stopping you from pulling the cluster out. Try looking up under the dash with a light and see if you can see those black plastic bulb holders. They just twist out and the bulb pushes in the holder. You might luck out if you can reach the one that is out :)
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    It's the fuse.
  7. mav1970
    It sounds like he is only talking about the light behind his speedometer, not all of the dash lights :)
  8. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  9. jtstein98
    jtstein98 Member
    near chicago IL
    1971 ford maverick
    ya its only the light for the speedometer. All the other light but that one work.
  10. WinterBlue71
    SC
  11. Red1972Grabber
    Northern California
    Welcome from Northern California!:chirp:
  12. jtstein98
    jtstein98 Member
    near chicago IL
    1971 ford maverick
    ok so I checked the bulb and the fuse and both are good? Any other ideas???
  13. Krazy Comet
    If the other side of the instrument panel is lighting, then you have either a bad socket or connection in the printed circuit feeding the socket...
  14. Mad Goon
    Mad Goon Scaring the Hondas
    Redondo Beach, California
    Welcome from Redondo Beach, CA!
    Probably the fuse on the fuse panel, mine went out before and I lost all my dash lights!
  15. Mercurycruizers
    Venetia, PA
    :Welcome:to the board...
