72 COW Grabber
Discussion in 'General Maverick/Comet' started by Slider28, Nov 9, 2009.
  1. Slider28
    Slider28 Member
    San Antonio, Texas
    72 Maverick Grabber 302
    2 years laters im STILL getting leafs outa me vents... If i drop the housing for the heater core will that be full of the rest of the limbs and leafs and etc... to clean out my vents???
    Chaz..
  2. Craig Selvey
    More than likely.....yes. Your cowl is probably full of them as well.
  3. Jeff S
    Jeff S Member
    NoVA
    none
    If your cowl is full of leaves and such and been exposed to the elements, more then likely youre going to have a lot of the forbidden R word...so be prepared...hopefully you wont see any.
  4. Slider28
    Slider28 Member
    San Antonio, Texas
    I looked down in there and its empty... NOW! but where do the leafs go from there? into the heater core box??
    CHaz.
  5. Popbumper
    Popbumper PINTO unashamed
    Dallas, Texas
    My car sat for years under trees, outdoors, before I bought it. If yours has experienced any similar circumstances, prepare to find loose leaves:
    1) Behind the dashboard itself
    2) Crowding the heater box floor prior to the dampers
    3) Sitting loose everywhere in the cowl, especially around the air intake hole
    Be warned; with the leaves comes requisite moisture, which means the potential for corrosion, compost, and all kinds of other guck. The only real way to attack it is what I am doing right now - removing and competely restoring my heater box. At a minimum, open the box and blow it out, and get some high pressure air up under the dash. Good luck.
    Chris
    PS - mine is also a Texas car!! They LOVE leaves......
  6. rthomas771
    I dropped my heater box and drivers vent and used compressed air to blow out the leafs. After getting a bag full I thought I got them all until I drove around the block. I had leafs blowing around inside the car for about a week.
    [​IMG] [​IMG]
  7. bmcdaniel
    When I saw "COW Grabber" I thought maybe you had painted your car white with big black spots...
    NM
  8. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    When I took apart what was to become my current heater/AC box to rebuild it during my AC install project, I found quite a bit of leaves and general debris in there. Not to mention a rodent's nest.
