72 Grabber stripes
Discussion in 'General Maverick/Comet' started by maverickdvm, Aug 20, 2008.
  1. maverickdvm
    maverickdvm Member
    Michigan
    What is the correct distance from hood edge and cowl edge to outside hood stripe? How about distance from hood scoop? Distance between center sections and between center sections and outside hood stripe? We have them laid out, just want to check and double check.
    Thanks,
    Sarah
  2. Dave B
    When we used the stencil kit from Graphic Express, it would only fit a certain way between the scoops, so we went with that, and I've compared it to other Grabber hoods I've seen (original and repainted) and it close enough, I can measure it for you tomorrow.
  3. maverickdvm
    maverickdvm Member
    Michigan
    Thanks! I have a Graphics Express decal that I can use to line it up. The decals I am using are custom ones from Lonnie. I just want to make sure everything is as perfect as I can make it(probably better than factory!).
    Sarah
  4. Craig Selvey
    I matched the curve of the stripe to match the curve of the hood around the scoops on each side. Space it the same as the spacing on the straight parts of the hood/stripe. Seemed to place it just right.
  5. maverickdvm
    maverickdvm Member
    Michigan
    Can someone take a picture of their hood from up above? All of the pictures from the side/front that I can find don't seem to show the overall layout well.
    Thanks!
    Sarah
  6. Dave B
    I don't know if this will help? I can get a better one tomorrow, it's too dark out.
  7. maverickdvm
    maverickdvm Member
    Michigan
    Potentially dumb question, but other than the split middle, are the 72 and 73 stripes the same outside diameter?
    Great picture by the way. Thanks!
  8. Dave B
    73 never came with those hoods, but as far as I can tell 71 & 72 are the same diameter. Other than one year was a decal, and one was painted. ( I didn't take the pic, Seth did)
  9. maverickdvm
    maverickdvm Member
    Michigan
    I knew there was a dumb part of the question. There wasn't something that I just couldn't wrap my mind around in that picture, I couldn't decide what it was.
    Thanks!
  10. SlotlessMan
    SlotlessMan A squirrel and his nut
    Chetek, WI
    71 Grabber
    Here is Lonnie's stripe.
  11. qicvick
    qicvick Member
    ft.worth,tx
    1972 grabber
    Is this for the yellow 72 grabber? :yup:
  12. maverickdvm
    maverickdvm Member
    Michigan
    Yes it is! It is looking good, the paint came out very nice. The stripes are laid out on it right, just have to stick them on. I will post pictures.
  13. qicvick
    qicvick Member
    ft.worth,tx
    1972 grabber
    Can't wait, never seen that color compo, mine had been repainted before I got it in 92!
