'73 Comet Radio Bezel Removal
Discussion in 'Audio' started by canuck222, Jul 1, 2020.
  1. canuck222
    canuck222 vroom, vroom... Supporting Member
    Woodstock, ON
    '73 Mercury Comet, 302, Auto
    I want to remove the radio bezel so I can cut it to fit a DIN sleeve for a modern radio, for the life of me I cannot figure out how it is attached. The bottom feels loose but the upper is secure.
    Can this part be readily removed (red rectangle) or do people just cut the blue area out with everything still in the dash?
  2. 71gold
    two screws at the top...
  3. canuck222
    Woodstock, ON
    I took two phillip screws out of the top front already. Will check again.
  4. 71gold
    i think there are two small studs on the bottom and two screws at the top.
  5. Acornridgeman
    Wisconsin
    From what I remember - When the 2 screws are out, it will tip from the top back into the dash and then lift it up to free the 2 guide pins. It does not pull out the front, it goes in and then out the bottom.
  6. Craig Selvey
    I seem to recall (3) screws need to be removed along the top.
    CA189HJN likes this.
  7. CA189HJN
    CA189HJN Robert Couse-Baker
    Sacramento, California
    1973 Ford Maverick 4-door 302
    To get to the three screws on the bezel, you'll need to remove the lower dash first.
    canuck222 likes this.
  8. GrabberT
    GrabberT Member
    1974 Maverick Grabber
    So I'm having the same issue except trying to put a bezel in. My car didn't have one when I bought it. Can't figure out how it goes in.
