73 maverick turn signal issues
Discussion in 'Technical' started by Creepingdose, Apr 12, 2014.
  1. Creepingdose
    Creepingdose Member
    Portland, OR
    1973 Maverick
    So I just got it out of the shop today. New engine and it runs great. break lights work headlights work high beams work, but my turn signals aren't working. When I turn on a turn signal It makes that break light not work as in (left turn signal on, left break light doesn't work) now I know/have heard that's because they share the same light. I checked the front lights they don't blink either. I bought a brand new flasher cylinoid, or relay and nothing changed. Is there fuses for the turn signals?
  2. Acornridgeman
    Wisconsin
    There is a bad ground someplace. Can happen just from sitting over winter. I have even seen the contact become poor between the bulb socket and lamp housing. It is a press fit and the contact surfaces can corrode between the 2 stampings.
    A little corrosion between mated metal surfaces can play havoc with the turn signals.
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Check the grounds.
  4. Creepingdose
    Creepingdose Member
    Portland, OR
    1973 Maverick
    Yeah I'm sure you are right. Thanks!
