74 Mav running rough
Discussion in 'Technical' started by Regicide408, May 6, 2012.
  1. Regicide408
    Regicide408 Member
    Bay Area, California
    74 maverick i6
    74 Mav 200 carter yf carb any help would be great thanks guys. Take a look at the vid.
  2. darren
    Choke should have been wide open.Sounds like its good and hot.
  3. Regicide408
    Regicide408 Member
    74 maverick i6
    So the choke should be wide open when car is hot?
  4. Regicide408
    Regicide408 Member
    74 maverick i6
    Adjusted the chocke. I am noticing that the timing is jumping around everywhere. Re-adjusted the timing. Now it's between 6-3.
  5. Regicide408
    Regicide408 Member
    74 maverick i6
    But still the RPMs drop in drive.
  6. darren
    Almost sounds like it has a vacuum leak.
  7. Regicide408
    Regicide408 Member
    74 maverick i6
    Checked all hoses all seam fine no leaks
