74 Maverick as my First Car
Discussion in 'New Members Forum' started by aGzSinis7eR, Feb 15, 2013.
  1. aGzSinis7eR
    aGzSinis7eR New Member
    United States,Texas
    1974 Maverick 4-Door
    Good yes? It's a 4-Door
  2. Red1972Grabber
    Northern California
    Welcome from Northern California!:chirp:
  3. mav1970
  4. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  5. Mercurycruizers
    Venetia, PA
    :Welcome:to the board....
  6. jncastell
    jncastell Member
    Ogden, Utah
    1974 Maverick Grabber Clone
    :Welcome: From Utah.
  7. maverick75
    I wouldn't get it as a first car, get a 4 cylinder import or domestic instead.
  8. junrai
    junrai Member
    rancho cordova ca
    if its a 6cyl its ok for a first car because it will run FOREVER if you keep oil and water in it.
    those ol 6 cylinders can stand ALOT of neglect and abuse and still run for 20 years.
    someone here said they used there maverick as a daily driver and never changed the oil once in 8 years! and it was still running when he decided it was time to start fixing it up.
    my sister had a granada with a 6 cyl in it and she would NEVER check the oil or water unless it was knocking or over heating. put oil or water in and repeat every 6 months or so
    perfect car and motor combo for a first car since first cars usually never get taken care of. the only thing I would recommend is a modern distributor so you dont have to deal with points. points can make or break a trip gas mileage and dependability.
    a bad set of points can leave you stranded somewhere and I can almost guaranty it will be when you are either in a hurry or have somewhere important to go
    modern distributors give you VERY LITTLE trouble if ever
