74 Maverick EGR issue
Discussion in 'Technical' started by falconscjman, Oct 5, 2012.
  1. falconscjman
    falconscjman Member
    phoenx, az
    74 2dr blue 250 6 cyl
    If I remove the EGR on my 1974 w/250 will that diversely effect the engine function? There is no smog pump or cat conv & I have classic insurance so I don't need to go thru emissions. Could I just use a pre 73 type carb spacer(for the intake) & just plug up some of the other existing vacuum plumbing on the original 74 carb & be good at that?
  2. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    just make a block off plate out of some thin metal and use the original gasket to seal it or use silicone then if you need to put it back you can just bolt it on
  3. don graham
    Should be no problem, Just cap off any vacuum ports you're not using. :)
