75 door panels
Discussion in 'Technical' started by squeal1, Jun 11, 2005.
  1. squeal1
    squeal1 Out To Have Fun
    Evansville, IN
    72 Maverick Semi Mod, 75 Project
    I have all the clips released that run around the out side of the panel but I can't figure out how the door handle release. Any help would be great, I need to get the glass out of the doors.
  2. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    You must remove the phillips screws that hold it in...
  3. 71gold
    there is a little black cover (cup) inside/behind the handle. take a small screwdriver and pry it out from the edge. it has ears on it so be carefull...if this is not helpfull enough then let me know and i will try to 'splain it better....frank...:bouncy:
  4. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    :biglaugh::biglaugh:I just learned this today, myself. You have to remove the black inner liner in the handle pull Bezel. Just use a small flat blade scewdriver and get one end up and pull the handle straight out and slide the liner over the handle. Now you can see the screw that TL is referring to. Unless you move that liner, which looks like it is part of the full bezel, you can't see the screw.
  5. squeal1
    Evansville, IN
    Thanks guys it looked like it was one solid piece, I thought maybe it had clips in behind it somewhere, I will get them off today so I can get something done :D:D
    Thanks again
    Neal
