Well heres the formula, got a 75 that had i-6. Installing v-8 unplugged wire harness carefully not to break any of retainers. Now question is will the i-6 green module work for the v-8 application? Right now we have points dizzy in engine. I do have an electronic dizzy. whats the best method and what will be needed. electronic would be perfered. I new this would be a area I might struggle,not quite sure but I am a damm good learner. Any help? Thanks,Mitch
Get the blue module. Use the coil off your I6. It should all plug right up, but if not, it's super easy to make your own Duraspark II harness.
