76 Mav Seat Removal Plz Help!!
Discussion in 'New Members Forum' started by 76MavProbie, Dec 7, 2010.
  1. 76MavProbie
    76MavProbie Member
    I need help! I am trying to remove the front bench seat, do I need a special tool? also trying to remove the panels on the door threshold that the seat belts move into. Any help or advice would be appreciated
  2. mercgt73
    There are four bolts that hold down the bench seat frame to the floor. Lay on your back and slide under the car, they are in the area of the bench seat frame corners.
  3. 76MavProbie
    76MavProbie Member
    Thanks, worked great!!
    Now how about the seatbelts, do I new a torx screwdriver?
  4. Streetdeacon
    Streetdeacon Streetdeacon
    Bellingham, WA
    1977 Maverick 2dr.
    I have a torques bit for 3/8 drive ratchet that I used on mine. Screw driver may not give you enough torque to get the bolt loose.
  5. 76MavProbie
    76MavProbie Member
    Seat Belt Retractor Unit
    Cool Thanks a lot!! Any clue on how to remove the seatbelt retractor unit?
  6. mav1970
    Where are you from? :Handshake
  7. Acornridgeman
    Wisconsin
    Use a T-50 bit for the seat belt bolts. And don't buy a cheap one. Cheap ones shatter like glass on these rusty old bolts. Buy the best, preferably one with a lifetime breakage warranty, you will need it. :dancing:
