76napa tank in 74
Discussion in 'Technical' started by Rob C, Apr 30, 2007.
  1. Rob C
    Rob C Member
    nj
    74 Maverick 250 3spd auto 78trans am 400 "some" go fast goodies:)
    was wondering what i would need to put the 76 napa tank into my 74. i know i will need the longer straps but was wondering about the vent on the top of the tank and the sender would the 74 parts work? or does the napa tank include the sender? any info would be great
  2. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    The straps work for the 74-77. The tank is the same. When you order the tank it does not include the sender unit.
  3. Craig Selvey
    You will need the bigger straps as the NAPA tank is bigger than your 1974 tank. All of your stuff (except for the straps) will switch right over.
