77 ford maverick takes about 10 minutes before going into drive
Discussion in 'Transmissions' started by Tilor64, Mar 12, 2013.
  1. Tilor64
    Tilor64 New Member
    Fort Worth Texas
    77 ford Maverick
    As the topic says, my 77 ford maverick takes awhile to "warm up" (sadly she's an automatic) she only has 76,000 miles too.
    I am no mechanic, but I assume it has something to do with the transmission.
    When I put it into drive right after I start it, it acts like its in neutral.
    I just had the transmission pan replaced and it ran well for a week or two.
    There are no leaks to my knowledge.
    After she does warm up she drives fine.
    Any suggestions on how to fix this?
    Hopefully it's a cheap fix haha
  2. 71gold
    :Welcome:...:Handshake
    these transmissions have been known to do this after a fluid change. do you have any service records for your transmission?
  3. Tilor64
    Tilor64 New Member
    Fort Worth Texas
    77 ford Maverick
    That must be the problem...
    Looks like I will need to save up some money for a rebuild haha
  4. Craig Selvey
    Try checking the fluid level first. Could be a little (or a lot) low.
  5. Krazy Comet
    I've seen loose valve body bolts act similar...
  6. scooper77515
    Mine is slow to engage if I haven't driven it in 6 months, and lots of fluid has leaked out. So, first and foremost, check your fluid level.
    The fact that it has to warm up and then works suggests to me that it is low when cold, and once it warms up and expands, it expands to just enough to make it engage. So I would guess you are about a quart low. Maybe a bit more.
  7. doncomfort
    chillicothe oh
    I had a 70 Failane that did the same thing. Took a good ten minutes or more before the trans would go into drive. Only did it first start of the day. Had the tranny rebuilt, took care of that. Never learned the cause.
  8. bmcdaniel
    Just leave for work 10 minutes earlier...
  9. ptpdub
    ptpdub Member
    canada Sk.
    mine did that. the transmission was in need of full rebuild.
  10. rthomas771
    Mine did that also. I replaced the trans with a good trans I got from Earl that he happen to have laying around
  11. Tilor64
    Tilor64 New Member
    Fort Worth Texas
    77 ford Maverick
    So I went to autozone and picked up some Lucas stop slip as well as some more transmission fluid.
    She needs to warm up when it's cold, but she doesn't take as long.
    So it fixes the problem slightly, but I'll be on the lookout for a new tranny, or rebuild eventually so the problem is solved for good.
    Thanks for all the help guys!
  12. simple man
    simple man Member
    Bunnell,Florida
    Make sure you only use " Type F " fluid! Anything else will cause issues. Never tried Lucas stop slip. I like their other products! :)
  13. 74merc
    74merc computer nerd
    1974 Comet
    Too much fluid can cause this as well. It'll get all foamy, typically doesn't clear up in 10 minutes tho.
    Not likely the cause in this case, just thought I'd mention it.
  14. ptpdub
    ptpdub Member
    canada Sk.
    sigh, did this too. I suck with transmissions. :cry:
  15. 74merc
    1974 Comet
    There are several ways to learn stuff, but to remember it 100% of the time takes learning it the hard way.:thumbs2:
    That being said, I remember a lot of stuff very clearly.
