Hey guys. I could use a little input. I've recently bouht a comet gt and wanted to know what parts should I salvage off of a Granada. It had a 302 and auto trans. I'm thinking the front brakes and maybe crossmember.
I need the proportion valve too right? I'll cut the lines above the connectors, get clips and all.how about tie rod ends.master cylinder? I want to put a 8.8 rear in it since it's easy to find 3.73 and 4.11 gears and limited slip carriers. Any info on that swap? Ill try to find an aluminum driveshaft too.
From the great NW. Just strip all you can off of it. If you don't use it you might be able to sell some parts to help finace what you want to purchase.
All the suspension and steering, rear axle, gas tank, and sending unit, floor hump if in floor shifter, seat tracks if bucket seat and console, mirrors , and the coolant overflow (bolts right in a maverick)
