77 mav 4,000k original miles
Discussion in 'General Maverick/Comet' started by Joe H., Oct 27, 2004.
  1. Joe H.
    Joe H. Member
    Mineral Point,PA.
    71 MAVERICK...302 4V
    Got an e-mail from a fellow mav owner that saw a rust free 77 mav, 4,000k miles, in storage since 1977. It was in a body shop getting extensive work done to drivers door. Owner turned the key on while car was in gear with door opened in garage. Owner is said to be asking around $3,500. The guy said it was a 6 cyl. not a speck of rust and very clean under hood. What do you all think of the price? Joe
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    how many doors?
  3. Joe H.
    Joe H. Member
    Mineral Point,PA.
    He said it was a 2 door, I'm going to see if It is still there and see it for myself
  4. dmhines
    Cumming, GA
    If it was truly in storage from 1977 ... means all the fluids are toast. Hoses are toast ... not sure it I would trust it mechanically without replacing lots of stuff on it ..
  5. Joe H.
    Joe H. Member
    Mineral Point,PA.
    Evidently the car runs. It is at the body shop now. I'm going to stop by on way home from work tomorrw and find more out about it and see it for myself. Either way it's unbelieveable to find one with 4,000k on it. And sounds like it's a standard shift the way the car was damaged.
  6. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    With it being in that shape sounds like it might be worth that much.
  7. black396
    black396 Member
    florida
    Comet
    One thing that a low mileage car has, that is hard to duplicate is the feel of a new car. All the little geegaws are there, the doors slam good, the glass is clear, the seats arn't crushed, all the buttons, knobs, screws, tabs, decals, brackets, gaskets, rubbers, flotsam and jetsam are there. A lotta that stuff can't be found.That really is nice.
    The low mileage can be deceptive. My son's 77 Buick, w/ 9500 miles, had a rusted thru oil pan. Imagine! The road salt, combined with the lack of leaks allowed rust thru!
    Is it an air car? any neat stuff like buckets, floor shift? Good color?
    If the body is straight and the door fixed, first class, and particularly if it is an air car, and a good color, I would spring for the deal.
  8. Maverick Man
    California
    an easy way to tell if its really that low miles and not only 4k but 104k.. is to pull a valve cover.. an easy way to tell on a car thats comming from someone thats not a gear head...
    but i'd like see what the thing looks like myself.
  9. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
    Can you get some pics? Sounds like it could be a nice find, if everything checks out.
  10. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Another quick tell-tale indicator of low-mile cars actually being a low mile car; examine the amount of wear on the brake pedal. If it's worn to the metal, well, you know.
  11. Maverick Man
    California
    good one! very true!
    but what if they replaced it... j/k i doubt it! :D
  12. Craig Selvey
    One of the car dealers I call on replaces the brake pedal rubber on every car he buys to resell. It is SOP (Standard Operating Procedure) at his dealership.
  13. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    Just read an article last night in CC magazine. A quick way of determining low/high mileage cars is pull one of the hub caps (if equiped). If it's fairly clean it could possibly be a low mileage car.
  14. Joe H.
    Joe H. Member
    Mineral Point,PA.
    Well everyone, I finally found this car today and believe me it has 4,272k original miles on it. Back in 1977 we had a flood here in Johnstown and this was in the flood. The guy drained and replaced all fluids then... it was his niece's car. For some reason the car then sat in a garage since then. He has put a little over $3,ooo into it recently to make it road worthy. It is dark brown, plain jane as they came. 6 banger,3 speed on collumn, tan or sort of yellow int. Paint is not really good and body has a couple little dimples from boxes and other normal garage clutter. But there is no rust any where. Perfect floor,trunk, door bottoms,the front inner spash panal was out for the door repair and the torque box area was shinny and clean! The spring and control arm stickers are still on there. Under the hood is the good part. The air pump,clutch and shift linkage, and all other components look never used and very clean. All the little yellow code or ok marks are in place also. Chrome isn't that great. This all I could get from the shop guy. I have the owners number and will call this weekend. I'll let you all know what I find out from him. Joe H
