77 Maverick
Discussion in 'Maverick/Comet Projects' started by mosey, Sep 9, 2009.
  1. mosey
    mosey New Member
    Southern Ohio
    1977 Maverick
    I've got a rust problem in the trunk area where the shackles bolt to the "frame".
    I'm not sure if I can rebuild the frame or put in a whole trunk piece.
    Any ideas would be well taken.
    Dave
  2. Craig Selvey
    Pictures would help.....but if the rust is extensive in that area....and the rest of the car is just as rusty....then might be time for another body.
  3. Rando76
    Rando76 Member
    Claremore, OK
    If you don't want to junk the body, you can do the frame rail and trunk floor repair with some work. It has been done by members here before.
  4. brainsboy
    brainsboy Member
    Tampa
    Replacing the entire trunk is not easy because its a unibody design thats spot welded to the framing. Unless your building an original show car I would just cut out the sections that are rusty and replace it with new metal. If the actual framing is bad you will need to find a donner car and cut out the section that holds the shackel.
  5. Rando76
    Rando76 Member
    Claremore, OK
    Talk to DaleMav77, I think he had the frame rails replaced from a donor car on his 4 door.
