8.8 in a Maverick
Discussion in 'General Maverick/Comet' started by Carver Speed, Dec 13, 2011.
  1. Carver Speed
    Carver Speed Member
    S.E. Mass
    70 Maverick, 65 Falcon
    Sorry if I've missed this somewhere, did a search but no hits. So anybody know if I can swap the 8.8 from a donor fox mustang into the 70 Maverick?
    Thanks,
    Jeff
  2. rwbrooks50
    rwbrooks50 Member Supporting Member
    Forney Texas
    71 Maverick & 63 Ranchero
  3. nickmav70
    nickmav70 Nick Maverick
    Dallas, GA
    1971 Ford Maverick
    Yes you can... Cut off the fox brackets and weld on spring perches... Fits fine with wheels with more backspacing... Stock wheels will probably stick out because the fox rear is wider
  4. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    I have one under mine, easy swap and I use 94 and up mustang wheels
  5. nickmav70
    Dallas, GA
    1971 Ford Maverick
    Same here... I use 99-04 bullitts and have a sn95 rear with discs
  6. Gsenkow
    Gsenkow Member
    Canada
    1991 Ford Ranger, 1974 Maverick
    My 74 has an 8.8 out of an explorer, it was narrowed so that the wheels would fit under the 1/4s.
  7. Dave B
    Some day I'll get around to installing mine....
