so ive searched and couldn't find anything , but a guy told me that mavericks came stock with an 8.8 is it true.
'70 mavericks had a 7.5" (plate cover) rear end. anything from 71-77 had an 8" rear, both 4 lug and 5lug alike.
How about some details on the 8.8 swap? I need to do something, and I could use another 3" wider housing to use the 4 7/8" backspace wheels I already have.
using a 8.8 housing out of a fox mustang is 1 inch longer per side than a maverick rear this is a pic of mine with a 17x8 rim with 5.72inch backspacing and a 275/40/17 tire it fits just about perfect for my taste brad
rear Did you use the 94-98 rear end? They were all the same length, 99 and up the housings are wider.
rear Did you convert to discs? That is what makes the 94-98 rears wider, the housings are the same but the discs add around .75 inches per side.
explorer 8.8, stock with 31 spline axles, 5 lug and disc brakes, only downside is my driveshaft is passenger side biased and hits the tunnel, need to clearance it yet
