8.8 swap.
Discussion in 'General Maverick/Comet' started by Dhal360, Dec 30, 2017.
  1. Dhal360
    Dhal360 Member
    Pleasant Hill California
    1970 Ford Maverick
    I have a 70 maverick that is in process to become a 302 from an inline. I want to put an 8.8 in it but of course am on a budget so I'm wondering what vehicles I could snag one from without much fabrication?
  2. 71gold
  3. Craig Selvey
    No matter which vehicle you snag one from, it will require modifications. Nothing will simply "bolt in".
    mojo likes this.
  4. Dhal360
    Dhal360 Member
    1970 Ford Maverick
    Fabrication is not something I'm too good at, but relocating spring perches is something I can handle. Cutting tubes and things a long those lines I would probably have to have someone else do.
  5. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I would go with the Mustang rear from a mid 90's GT if I were going to do an 8.8 swap. The width isn't that much different, since you're going from 4 lug to 5 you need to get wheels any way so you can pick back spacing to fit. Much easier to do just the perches rather than an axle tube and perches.
    Dhal360 likes this.
  6. Dhal360
    Dhal360 Member
    1970 Ford Maverick
    Thanks Rick, I appreciate that information, my local pick and pull just so happens to have quite a few mid 90's mustangs right now. Looks like I know what I'll be doing this holiday weekend.
  7. Craig Selvey
    It is not just welding on on the new perches. They have to be welded just exactly right as far as pinion angle. Close enough will not work. :D
    71gold and mojo like this.
  8. RMiller
    Kennewick, WA
    Good point Craig, it's so easy to assume people just know these things! For those that aren't familiar with setting pinion angles, Tremec has an app that will take your angles and give you a go/no go on what you have.
    https://play.google.com/store/apps/details?id=com.Tremec.tremec.app
