8" members
Discussion in 'General Maverick/Comet' started by timsrick, Jan 31, 2008.
  1. timsrick
    timsrick Member
    woodville,ont.canada
    1977 maverick,77 comet
  2. Jamie Miles
    Prices seem a little ridiculous? Cheapest I see is $775.00 for an open rear? The rest are over $1,000. I think I'd turn to ebay first.
  3. ericglo
    ericglo Member
    n/e illinios
    1972 maverick
    There is place on e-bay that sells new 8" posi third members any gear for $750.00
  4. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    If you're not too hip on using ebay, you might want to try this site:
    http://www.justrearends.com/
    Their prices are lower by about $200 or so than your site above. :D
  5. timsrick
    timsrick Member
    thats pretty good as well.thanks
  6. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    Oh! When I seen 8" members I thought you where talking about me and Hawko! Hmmmmmmmmmm!
  7. Dave B
    :rofl2:now that made me laugh!!! Thanks!!!:rofl2:
  8. bmcdaniel
    8" isn't very tall.
  9. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    They used to be called Metro Mustang ... on the South Side of Atlanta .. They have a pretty big classic Mustang Salvage yard ...
  10. don graham
    Tom, you don't need to explain how you know this information.:scratchchin::outtahere:
  11. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    9" rears are so common, and aftermarket parts are way cheaper than 8", I don't know why anyone willing to spend this kind of money on a rear doesn't have a 9".:huh:
    You can a get really good 9" chunk for same money or less, 200 bux to change the tubes on a donor housing, and you're done!
  12. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    In my case weight savings(y)
    A 9inch robs power and adds 75lbs.
    Since I am using an alumin8 chunk and pinion support it is even more.
    Add some dutchman axles and ARP everything. That 8 inch will hold up:tiphat:
  13. ratio411
    ratio411 Member
    Pensacola
    Where do you get 75#???
    The regular housing is 3# more and the entire chunk is 8# more.
    Now if you go all out with HD housing, stock N-case, stock 31 splines, etc... you are looking at close to 30#.
    Still no where near 75#.
    All the aftermarket stuff is lighter, and far more options are available for lightweight and aluminum parts vs 8" stuff.
    I imagine that aluminum chunk cost as much or better than one of the many 9" aluminum chunks out there.
    I am not trying to get into a p'ing match, but the differences aren't that great, except for strength.
    Some 9" drum brakes are very heavy, but only because they are much larger. 8" drums will bolt right to a small bearing 9", or better yet you keep them when you use your 8" tubes.
    Crown Vic and Exploder discs are even lighter and better.
    Versillies discs are very heavy, FWIW.
    Just a heads up.
  14. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    Whatchu talkin' 'bout, Willis?:hmmm:
  15. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    I'm pretty sure I don't want to know.:naughty:
