8" Or 9" Rear????
Discussion in 'Technical' started by JLUDE96, Jul 14, 2007.
  1. JLUDE96
    JLUDE96 Member
    BALTIMORE
    1970 MAVERICK
    i just got a 70 mav with a 302 motor from a 73 comet. The old owner says that he took the motor, trans (c4), and rear from the comet. how can i tell what size the rear is. It also has the 5 lug front and rears. Any help with finding out what i got??????
  2. JLUDE96
    JLUDE96 Member
    BALTIMORE
    1970 MAVERICK
    I also noted that the left rear shock is rubbing the rear end housing?? Is this an install problem or possiable wrong rear/shock combo???
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    If you cannot get a socket on the 2 bottom nuts on the center section it is a 9".
    1970 cars did not come with staggered shocks. It is likely someone installed the bottom plates from a staggered shock car which is causing the shock to contact the housing.
  4. Mavaholic
    All Comets had an 8" rear. Very early 70 model Mavericks had a 7.5 but the rest of them were 8s.
  5. JLUDE96
    JLUDE96 Member
    BALTIMORE
    1970 MAVERICK
    my car does have the staggered rear shocks. the old owner did say he changed the rear from a 73 comet. does anyone have the correct lower shock plates?????
  6. Craig Selvey
    I don't think it is the bottom shock plates that is the problem....I think it is the upper mounts. If the car was originally a 7.5" rear axle and did not have the staggered shocks....then I THINK the upper mounts would be different.
  7. JLUDE96
    JLUDE96 Member
    BALTIMORE
    1970 MAVERICK
    is there a way to tell what originaly came in the rear (7.5 or 8). where would the mounts go and came it be converted to the 8 or 9 rear with shock problems
  8. maverick1970
    Missouri
    The upper mounts are different. Does anyone know if they can just be swapped with the staggered brackets?
    When I did the swap on my 70 I installed Lakewood Traction bars which replaced the lower plates and came with both front and rear position shock mounts.
  9. Craig Selvey
    I don't know if the top mounts can be swapped or not....but I would think something could be "fabricated" and made to work. I can't imagine it would be that difficult.
    I suggest you come out the the MCCI Roundup Nationals the weekend of July 27-28 in Washington D.C. area and look at all the cars and I am sure we can figure something out.
