8" Rear Stock Gears
Discussion in 'Technical' started by Bioinfomatic, Aug 17, 2007.
  1. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    I don't know but maybe you guys can help me; What are the stock gears that come in a 77 maverick? :huh: I'm really not sure if I read the tag on the center section correctly but I think it said "2.79".
  2. Mavaholic
    It was either 2:79 or 3:00 so I'd say you read it right.
  3. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    Thinks a lot, but on another note I really don't know what is so special about gears anyway.
  4. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    The gears have everything to do with how many RPM's your engine turns at certain speeds. Let's assume you are running stock 14" tires that are 26" tall, here is the MPH at different gearings while running 2,500 RPM:
    2.79 gear - 70 MPH
    3.00 gear - 64 MPH
    3.25 gear - 60 MPH
    3.55 gear - 54 MPH
    3.70 gear - 52 MPH
    4.11 gear - 47 MPH
  5. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    So low gears give a car better acceleration at low rpms.
  6. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    First of all, 2.79 is considered a high gear and 4.11 is considered a low gear.
    You want a 4.11 gear on the drag strip because you want the quickest move off the line and to be a top RPM at the finish line. You want a 2.79 gear to drive on the freeway for a long trip. The lower the RPM, the better the gas mileage.
  7. baddad457
    Numerically low gears make the car slower in accelleration. Numerically higher gears make it faster in accelleration. A numerically high gear ratio is what's considered a lower gear ratio, does that confuse you ?
  8. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    This almost sounds like clicking start to shut down your computer.:hmmm:
  9. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    :hmmm: Confusing, but I'm learning.
    So for a mild mannered 302...thats a daily driver and weekend road warrior, I should go with a 3.00 or 3.25 gear setting?
  10. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    For an engine that you don't spin up over 5,500 RPM, a 3.25 gear is an excellent choice. If you spin up 6,000 RPM or so, 3.55 would be good. An ideal setup is a 3.55 or lower gear with either an AOD or 5-speed.
    Just a reminder, the previous remarks were my opinion and not to be construed as genuine fact.
