85 302 ho roller. Pulley help!
Discussion in 'General Maverick/Comet' started by bjcq323, May 18, 2012.
  1. bjcq323
    bjcq323 New Member
    NH
    1975 mercury comet
    Just got the 302 back from the shop freshed up. Putting into 75 comet. I need some help on water pump rotation and the best (junkyard) candidates for the pulley setup. Any nightmare scenerios i might run into and retail spots if i have too.Thanks for any suggestions. You are all the best....
  2. igoback70
    igoback70 Member
    IN
    70 Maverick
    If your going to run a V-belt setup, just get a water pump for a 75 comet 302 (30-$40) and order a set of March pulleys from Summit ( 120ish i think ). 160 bucks should do it.
  3. igoback70
    igoback70 Member
    IN
    70 Maverick
    I was way off on the pulley price, just looked and a 3 pc set will run ya 195, i dont think i paid that much, but then again i bought mine 13 years ago. GL on the build.
  4. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    I just used 5.0 pulleys i think the waterpump was for a 85 crown vic.I dont have power steering or A/C that might complicate things.
  5. bmcdaniel
    I used a standard rotation pump on a '74 timing cover and late 80s Crown Vic pulleys so that I could use a poly belt to turn the 3G alternator. With the old alternator I ran a v-belt using old stock Ford Mustang / Falcon pulleys.
