85 351-w is this block worth it???
Discussion in 'Technical' started by lynhrt210, Nov 14, 2011.
  1. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    Ok so im looking into getting a 85 351-w from abuddy and was wondering if this block is worth building up, i already did a search but no info on this block. Thanks
  2. maverick75
  3. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    Awsome and for 80 bucks you cant beat it lol
  4. olerodder
    olerodder Member
    NorCal
    Well, the 69 and very early 70 blocks were 9.48 deck height, the mid 70 through 74 blocks with 9.5 deck height are actually about 8/10lbs heavier, and all the weight is in the main bearing area. I just paid $350 for a std bore 71 block that had been mag'd/cleaned.
    The current block in the car is a 408 (I will be using the H-beam rods/4330 crank and Probe pistons in the $350 block. The old motor did a 9.801 last year in the Maverick and was tired(and it was a 72 block)...................I never went over 6800rpm and will also use this as a limit on my rebuilt stock block 408. Oh, did I mention the motor had been built in 1999 by CHP and was still running strong................early stock blocks are really good and I believe can handle 700hp.................If you are going to be spinning a motor over 6500rpm you had better think twice about external balancing and do it internally if you want it to live a productive life on the strip.
    As long as you don't spin it too much I believe the earlier blocks can do 700hp.............the later blocks, well 8/10lbs less material in the main web area is a LOT.
    IMHO
  5. maverick75
    The good thing about cubic inches is that it brings the power band down, so you can make the same amount of HP as a High reeving 5.0L at a lower rpm :)
  6. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    Awsome, im gonna use my heads off my 302,but do i have to get a roller cam with it or stick to hydraulic??
  7. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    did anyone catch the last post of that FM thread? The person claims the rod length is what makes it a 408.
