85 Mustangt Gt Dizzy in the Mav!
Discussion in 'General Maverick/Comet' started by superlead76, Mar 21, 2011.
  1. superlead76
    superlead76 Member
    Tampa, FL
    1972 Maverick Grabber 347!
    Hey guys...Does anyone know how to wire up and 85 mustang gt dizzy in a Maverick V8? Thanks guys!
  2. maverick75
    What kind cam do you have? Did the dizzy come from an auto or manual? And are you going to use a duraspark module or an MSD box? Either way you can find hundreds of write ups on google. There's one on here also in the tech article section. Under "duraspark swap".
  3. superlead76
    superlead76 Member
    Tampa, FL
    Got it. Thanks! I was just gonna go stock ignition. I guess that would work! Haaa...... The diz is from a manual btw....
  4. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    1974 grabber, 1995 mustang GT, 1967 mustang coupe, 1956 Caddilac sedan Deville
    Make sure your using the right disty gear for the cam in your engine.
  5. superlead76
    superlead76 Member
    Tampa, FL
    Yep! Steel gear for the roller cam! :)
  6. maverick75
    If you have a roller cam your golden. If you have a flat tappet then you need to swap out the gear on the dizzy to a cast iron/sintered metal one.
  7. Bryant
    the 85 distributor should just plug into your duraspark box.
  8. superlead76
    superlead76 Member
    Tampa, FL
    That's just it. I don't have a duraspark box. Guess I gotta get one.....or an MSD. :)
  9. Bryant
    you can get a dura spark box, any aftermarket ignition box that works with a magnetic trigger like msd, or you can use a gm hei module.
