9 inch rear end questions
Discussion in 'Technical' started by dgg54u, Jul 26, 2011.
  1. dgg54u
    dgg54u Member
    New Orleans area
    1972 Maverick Grabber
    I got under the car recently and noticed there were no rear shocks. the previous owner installed a 9 inch rear end but did not have lower shock mounts.. I found a 71 at junk yard that had the mounts but the hole pattern was too small... does anyone know of a compatible lower shock mount I can use to match the upper Maverick mount?? or can someone offer alternatives??
    Thanks!!
  2. Tyler70
    Tyler70 New Member
    Arizona
    '70 Maverick
    Why not just weld a bracket onto the housing, or the spring plate?
    Shouldn't be to difficult.
  3. tody
    tody Member
    cologne, germany
    the 9 inch has thicker axle tubes. slot the holes on the spring plates until they fit.
  4. baddad457
    Buy a Set of Lakewood traction bars, these have the shock mount holes in the lower plate that replaces the spring pads. The set I have on my 77 Comet is for a 67-70 Mustang
  5. dgg54u
    dgg54u Member
    New Orleans area
    9 inch rear end issue
    thanks for the suggestions!!
