91 mustang motor in maverick hooker headers hiting on driver side
Discussion in 'Technical' started by jaxster010, May 11, 2012.
  1. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    just swapped a 91 mustang 302 motor and trans into my maverick and i got hooker headers for the 302 grabber motor there 6901 or 9601 part number from jegs does anybody know if iam going to have a issue on the driver side clearing
  2. Big
    Big Member
    North Idaho
    Measure the space you have available and compare it to the specs of the headers. Its the only advice that I can give you without trying the fit and seeing hands on.
  3. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    ok cool ill try that has anybody try those headers on the car yet
  4. mercgt73
    Although I am not one of them, there are plenty of people using 6901 headers. Do a search for them.
  5. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I have them on my car. Several people have reported fitment issues. Most common is the pitman arm hitting a tube limiting the turning radius.
  6. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Will need a drop bracket if you're running power steering, but 6901's do fit. Far as I can tell they seem to be the most commonly used headers on this forum.
  7. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    ok cool yea not runing power steering so ill take a shot at it toinght the passanger side was fine so ill see how tight fit driver side is going to be
  8. MICHAEL DAVIS
    MICHAEL DAVIS Member
    1973 Ford Maverick
    From all the threads ive seen 6901 fits the best.
  9. injectedmav
    injectedmav Member
    Georgia
    Running 6901 hookers. They just barely touch the steering box and the pitman arm hits at full lock. Other than that they fit well.
  10. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    ok cool thanks whats the difficutly level on puting those hooker headers on the driver side while motor is in the car
  11. tody
    tody Member
    cologne, germany
    jack up the driver's side of the engine an inch or two. helps getting the header in.
  12. don graham
    Like Tody said. You need to jackup the drivers side of the motor a couple of inches. Pull the motor mount bolt out. I also loosen the passenger side bolt a little. Also have the car jacked up as high as you safely can.:)
  13. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    Ok cool thanks guy i will start on that this week
  14. doncraft
    doncraft Member
    Monroe WA
    1970 maverick 68 Ranchero
    I'm one of the guys that had to redo one of my primary tubes that the pitman arm hit.:mad:
  15. WesCoaster71
    WesCoaster71 Member
    california
    1971 ford maverick A.O.D trans 302 5.0 cu
    soo thats it just remove sparkplugs and motor mount bolt and jack up the engine? hmmm i must have been doing somthing wrong cause i couldnt get the ds to fit:huh:
