91 mustang motor
Discussion in 'Technical' started by gwil81, May 26, 2009.
  1. gwil81
    gwil81 Member
    oakland,ca
    1977 maverick
    im in the middle of 91 h.o. swap in my 77 mav what oil pan,oil pan gasket, an dip stick do i use? im running carb for now
  2. Mavman72
    you will need a front sump oil pan and oil pump pickup screen/tube.
    You will also need a Front cover that has the hole for the dipstick tube if your exhisting one does not have the boss on it to drill out.If you keep the serpentine belt set up you will not have to change over to a standard rotation water pump and front cover.The oil pan does not care which pan gasket you get.The pan rail is the same regardless of the configuration of the pans.
  3. mean_maverick
    what Peter said :yup:
  4. baddad457
    If you're using the Felpro 1 pc oilpan gasket, the front sump uses a different part number.
