98 block what bell housing will bolt up
Discussion in 'Transmissions' started by GITRDONE15, Mar 13, 2010.
  1. GITRDONE15
    GITRDONE15 Member
    i have a 71 ford maverick with a inline 200 6...auto ....what bell housing do i need to get to make this happen?.....its driving me crazy....i know i need the 50 oz 157 toooth flex....but to find a bell housing that will bolt up to the 98 ford explorer block is killin me......anyone help me out?
  2. bmcdaniel
    bmcdaniel Senile Member
    I assume you're talking about a 5.0 block? Any bellhousing from 1966-up will bolt up. What tranny are you planning on running?
  3. GITRDONE15
    GITRDONE15 Member
    98 302 yeah....i have a c-4 tranny in the car.....but i had talk to a guy he is sending me the correct bell housing for it becuase the one on my tranny is rounded becuase i have the small inline 6 in there.....Now im trying to find the correct timing cover and harmonic balancer to run a old school belt system
  4. bmcdaniel
    I used a 74 timing cover and a Professional Products damper on my 5.0.
  5. GITRDONE15
    GITRDONE15 Member
    cant i just us a oem balancer from a 71 302 and then bolt a crank pully onto that?
  6. 71gold
    if you trust the...31 year old...rubber in the balancer...:yup:
  7. GITRDONE15
    GITRDONE15 Member
    well i can get a new balancer in dorman but i was wondering if u guys know if a stock balancer from a 302 will be ok with that 50 oz flex....also where can i get a crank pulley for v groove belts
  8. baddad457
    No, you need a 50 oz balancer to match the crank and flexplate. Your best bet is to rob all this off a late 80's to 91 Crown Vic, Lincoln Towncar or Merc Marquis 5.0. You'll get the correct timing cover, balancer & waterpump to use V-belts, or use the Vic's accessories. The mid 80's Vic 5.0's still had the fuel pump boss cast into the timing cover, although the hole thru it wasn't always opened up for the fuel pump. You can easily forego the mech fuel pump anyway by using a MrGasket 12S electric pump.
