A 77' Maverick with all drum brakes?
Discussion in 'New Members Forum' started by team trav, May 27, 2014.
  1. team trav
    team trav Member
    Oakland, CA
    77 ford maverick 6cy
    hello fellow owners:
    my car:
    1977 Ford Maverick 250/inline6 4.1L
    This beast has 4 drum brakes?
    From what I found, 77s had disc brakes in the front.
    I did the control arms and the brake brackets look stock and
    unchanged and I doubt the previous owner would reverse brake
    technology. I've read the 75' was the last 4 drums.
    I pulled the front drum and it has about 2.25 width surface.
    I'm going to pull the rear to compare the size/no biggie.
    My question is did Ford make a 77' with all drums?
  2. Acornridgeman
    Wisconsin
    All were made with disc by '76 - some in '75 were still drum but that was the end.
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Are you sure your Maverick is a '77?
  4. team trav
    team trav Member
    Oakland, CA
    pretty sure...I got old DMV paperwork(previous owner), old smog report matching VIN and 11 digits...starting with 7K9.
  5. Krazy Comet
    Either the info about the '77 not having drum brakes is incorrect or you possibly have a re-VINed vehicle that is a earlier model... Of course brakes could have been swapped but that doesn't seem likely...
  6. 71gold
    another one to add to..."The Maverick Mysteries"...:cool:
  7. mav1970
  8. mav1970
    Seems like it might be a 75 - popular swap is drum to disc but not disc to drum so I don't know why anyone would want to convert a 77 disc car to drum brakes - does your car have the big bumpers on it?
    Give us your VIN number from the top of the dashboard on the drivers side - find it by looking down at the dash through your windshield - the old paperwork you found might not even be for this car :)
  9. Acornridgeman
    Wisconsin
    ......... and the drivers door jam - look for the ID plate and see what that says. Compare that to the dash VIN.
    Take a picture of it and we can decode it for you.
    :Welcome:
  10. Acornridgeman
    Wisconsin
    Oh, one more '77 thing. Does it have an emergency brake pedal or a handle you pull ........ :idea:
  11. Craig Selvey
    No mystery. If it is REALLY a 1977....somebody has changed out the brakes. NO....and I do mean NO 1977 Maverick came from the factory with disc brakes.
    I know of a 1977 Maverick running around with 4-lug front drum brakes and a 4-lug rear axle. Why? Because I sold the kid the parts to do it. He bought a 1977 Maverick that had the disc brakes and rear axle robbed for a swap to another car. He wanted to get the car on the road and as cheaply as possible. He didn't want to fix it right....he wanted to fix it cheap. Hence....it now exists.
    1975-1977 all had the foot pedal parking brake.
  12. Acornridgeman
    Wisconsin
    Which is why I asked. Cause if it has a pull brake it would be another reason it could be an earlier drum brake car. :)
  13. team trav
    team trav Member
    Oakland, CA
    7K91L101755...went to vinwiz.com and it gave me a 77' ID.
    my car does have a spring pedal/pull release E brake.
    btw, guys, this forum is great! thanks for the comments/answers.
  14. Acornridgeman
    Wisconsin
    Is that the VIN from the dash and the door jam sticker?
  15. team trav
    team trav Member
    Oakland, CA
    both the door and the dashplate.
