a bit better
Discussion in 'Drag Racing' started by JHodges, Apr 21, 2013.
  1. JHodges
    JHodges thumper
    Dora Alabama
    went to the track again and it done better. The balancer is covered in paint plus I didn't bring a timing light. I guessed the timing and seemed to have done better. It went a new personal best of 8.44 with a 1.84 ft. I also went a new best 60ft of 1.80 but decided to shift at 5800 and the car only went an 8.57. I plan to try again next week and have a timing light so the car may run 8.30's or so. all in all I am pretty satisfied with the car even if it's slower than an lt1 firebird lol
  2. 71gold
    if you guessed at the timing, you could have bumped it up/down a little to see what if any difference it made. the light is only going to tell you...what it is...the motor will tell you...what it wants. try setting it with a vac. gauge...:bouncy:
  3. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Just to give you a rough idea about timing.My old bigblock pickup always ran 12.90's had the distributor out and plopped it back in where i thought it was seemed to run fine went back to the track and it only went 14.00's. Borrowed a timing light checked it was at 40 deg set it at 32 only moved the dist a 1/4 to achieve that and the thing went 12.70 best pass ever.So yes timing is critical.
