A/C box rebuild question
Discussion in 'Technical' started by Datsunrides, Jul 22, 2025 at 12:03 AM.
  1. Datsunrides
    Datsunrides Member
    Roseburg, OR
    A lot
    I’m in the process of rebuilding a 76’ A/C box. My question is how to remove the fresh/recirc flap and the temp flap. I’m guessing that you probably have to unbend the tabs on the flaps that are folded around the pivot shaft then the pivot pulls out the side? IMG_1319.jpeg IMG_1318.jpeg
  2. rthomas771
    100_3971.JPG 100_3966.JPG Don't go bending anything. Remove the clip at the end of the hinge with a screwdriver and pull the hinge out of the heater case.
  3. Datsunrides
    Datsunrides Member
    Roseburg, OR
    A lot
    Thanks. This mostly worked. I was able to get the temp pivot out but the recirc was rusted in there. Started to damage to box so had to cut the folded over part so I could pry the flap open to remover the rod. Need to go post a wanted ad now.
