A/C Compressor
Discussion in 'Technical' started by FMSprint72, Aug 11, 2011.
  1. FMSprint72
    FMSprint72 Member
    Louisiana, Missouri
    1972 Ford Maverick Sprint
    will the A/C Compressor off of an 250 inline 6 banger fit a 289 motor? I am thinking of dropping a 289 in the Sprint and it doesn't have an air compressor.
  2. Craig Selvey
    Air compressor is the same. How it mounts is different.
  3. FMSprint72
    FMSprint72 Member
    Louisiana, Missouri
    ok, so what do i need to do to get it swapped out, like what kind of brackets and everything?
  4. Craig Selvey
    You will need all the V-8 brackets for the compressor. Anything off of a 289/302...maybe even a 351 will work. Pickups, Granada's, LTD's....pretty much all the same.
  5. FMSprint72
    FMSprint72 Member
    Louisiana, Missouri
    thanks, I appreciate it.
  6. krelboyne
    krelboyne Remember
    Salem, Oregon
    Brackets and pulleys should be matched year specific.
    351 pedestal brackets and lateral brackets won't work. The 351's have a taller deck height.
    *Note - I have researched this for 1967-73 cars. I can't say for certain for later brackets and engines.
