A/C control bezel tabs
Discussion in 'General Maverick/Comet' started by Eddie Maverick, Jun 16, 2008.
  1. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    I just got done with the switch replacement for the delay wipers today.
    Pretty straightforward install, but upon removing everything to get the switch in I noticed that the tabs(tits) that hold the a/c control bezel were gone. I always noticed it being a little loose, but when I got it off I was able to finally figure out why. Anybody got any tips or tricks on how to repair the tabs, or do I need to start looking for a new bezel?
    Thanks guys
  2. Mavaholic
    A little bead of silicone across the top and bottom will keep it in place. Dont put so much that it oozes out around the edges when you press it on.
  3. Craig Selvey
    A little two sided tape works well also.
  4. Rando76
    Rando76 Member
    Claremore, OK
    That's what I used too. (y)
  5. Dave B
    Me too. :thumbs2:
  6. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    Thanks guys, Never even thought of using silicone or double sided tape. I guess I was overthinkin things a little.:)
    Thanks again
  7. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
    When I still had a Maverick dash in my Mav, the bezel had small pieces of Velcro glued where the pins used to be (instead of double stick tape)...so that way you could remove it and put it back with less hassle if you needed to... :)
  8. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    After I posted my response earlier, I kinda thought that would be a easy option as well. I'll probably end up using velcro as I would want to be able to easily remove it for bulb changes and stuff.
