a/c indash question
Discussion in 'Technical' started by flynbrd, Apr 27, 2009.
  1. flynbrd
    flynbrd Member
    which vehicles can I pull the in dash a/c system out of to install my 72 maverick? Just wondering what years will work.
    thanks
  2. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Will whore to start !!!!
    The easiest way is to find a 71 / 72 mav / comet and pull everyting under the dash including the dash and you will have all the parts you need ,( this is what I did ) get a paper templit of the a/c side of the fire wall the holes are differant .. Get the heater - a/c controls , vaccum lines control cables every thing you can get .. Replace heater core , pressure a/c evap. core , reseal heater doors replace H block ( expanion valve ) check ALL vaccum motors get ALL DEFROSTER ducting . Than you will have all the parts you need under the dash then you can start under the hood as I did ..
    I know this does not awnsere your question but I hope it helps ..
    I did my a/c install for under 1000. with ALL new parts under the hood ..
    Jay
  3. flynbrd
    flynbrd Member
    a/c parts
    Well I think this mav had a/c but some point one of the owners yanked most of it out. The controls on the dash indicate a/c options and the dash has the a/c vents. I have yet to yank out the whole system to see what lies underneath.. (should be this friday I'll have my answer) In the meantime I was going to scout out the boneyard
    thanks
  4. flynbrd
    flynbrd Member
    The blower motor is located under the dash not in the firewall into engine bay. Does this mean the climate box is a/c?(for note there are no fixtures coming out of the firewall for heating or cooling)
    Thanks
  5. Craig Selvey
    Yes....AC box.
